TallyDrive – Get up to 3 GB free secure Cloud Backup for TallyPrime
Get up to 3 GB free, secured cloud backup storage with active TSS.
Thoughtfully built to keep you compliant.
Active TSS is required to access TallyDrive.
Simplified business solutions
The smarter, safer backup for TallyPrime
Keep your business data safe and easily accessible with TallyDrive’s secured cloud backups. Set it once and let TallyDrive handle the rest. Enjoy free cloud storage of up to 1 GB for Single-User and 3 GB for multi-user plan. Smart compression reduces backup size by 10×, enabling faster storage and secure, access-controlled sharing with CAs.
Key benefits
Your Tally data stays safe, backed up, and ready whenever you need it — no manual effort, no tension.
Your books of account remain protected through:
  • Scheduled daily backups to support compliance obligations
  • Secure, cloud-based storage for enhanced data protection
  • Continuous accessibility and recoverability whenever records are required
Set your preferred schedule — daily, weekly or monthly.
TallyPrime will back up your company data automatically to:
  • Your local drive, or
  • TallyDrive (recommended)
  • You focus on business. Tally takes care of the rest.
Made a mistake? Need older data?
Restore:
  • The latest backup, or
  • Any previous version (incremental backups)
Full control. Zero stress.
With incremental backups, only the changes since the last backup are saved. This keeps backup time fast and reduces storage usage — perfect for busy businesses.
Your Tally backups are stored on Tally’s secure cloud, ensuring:
  • High availability
  • Safe access
  • Zero risk of local machine failures
Backups are compressed up to 10× to save space and can be securely shared with CAs whenever needed with access control
Activate TallyDrive in just a few steps
Activating TallyDrive is simple and it’s already included with TallyPrime. To start using FREE cloud backup on TallyDrive, just ensure TallyPrime Release 7.0 or above is installed and an active TSS subscription is in place.
Once enabled, select TallyDrive as the backup destination and set a schedule. From there on, backups run automatically in the background — secure, reliable, and always ready. Here's how to get started with TallyDrive:
Interactive TallyDrive Setup Guide
See the demo for the process to claim free TallyDrive
Watch Demo   icons
FAQ
You can schedule automatic backups in TallyPrime and choose TallyDrive as the backup destination. Once set up, your data is backed up to the cloud automatically based on the schedule you select.
Yes. TallyDrive uses secure cloud infrastructure from Tally, ensuring your data is protected against system crashes, accidental deletion, hardware issues, or local machine failures.
Yes. TallyDrive works only with an active TSS subscription. Without TSS, access stops and your data stays stored for only 90 days.
You get free storage with an active TSS:
  • 1 GB for Single-User TallyPrime
  • 3 GB for Multi-User TallyPrime
You can start using this instantly after renewing TSS.
You can restore your latest backup or choose a previous version directly from TallyDrive. Version-based restore helps recover data from any point in your backup history.
Your TallyDrive data stays safe for 90 days after TSS expiry. However, you cannot access or create new backups until you renew your TSS
Need more storage?
If your free storage (1 GB/3 GB) runs out, simply purchase more.
Starting at ₹1200/year for 10 GB, you can expand as your business grows.
Buy now   icons
