    GST Codes: What are the SAC and HSN Code List?
    Pramit Pratim Ghosh
    Pramit Pratim Ghosh
    Updated on May 13, 2022
    Introduction to SAC and HSN Code Lists
    HSN Codes and SAC Codes are standards when it comes to classifying goods and services. In GST, the importance of the same as increased, in order to be clear about the taxes which are levied.
    What is HSN Code?
    HSN stands for Harmonized System of Nomenclature . It is an international classification system of commodities, which has been developed by the World Customs Organization (WCO). The WCO is an organization of 181 members, most of whom are developing countries, responsible for managing more than 98 percent of world trade. HSN aims to standardize the classification of merchandises under sections, chapters, headings and sub-headings – which results in a 6-digit code for each commodity. In a world divided by languages, HSN brings in a standard code, which ensures that commodities of similar nature are classified properly.
    India has been a member of the WCO since 1971 and has been using HSN codes since 1986 to classify the commodities for customs and central excise. Later, 2 more digits were added for better differentiation at customs and excise, which resulted in the 8-digit code, in use today.
    What is SAC Code?
    SAC stands for Services Accounting Code – which is a unified code for recognition, measurement and taxation of services. SAC has been in existence from the previous regime itself, and have been defined for each type of service by the government for the proper levy of Service Tax. The same code is expected to continue in the GST era.
    HSN & SAC code List in GST
    Under GST, all goods and services supplied in India have been classified - Goods are classified under the HSN Code and Services are classified under the SAC Code. Based on the HSN or SAC code, GST rates have been fixed in five slabs, namely 0%, 5%, 12%, 18% and 28%.
    In the GST regime each invoice will have to mention HSN code for all goods which are sold and SAC code for all services which are provided. Businesses will thus, need to be aware of the HSN code list and SAC code list for all GST applicable supplies they are dealing in. Under GST, majority of the dealers will need to adopt two, four, or eight digit HSN codes for their commodities, depending on their turn-over the previous year. The following are the detailed requirements:
    • Businesses with turnover of less than INR 1.5 crores - will not be required to use HSN codes
    • Businesses with turnover between INR 1.5 crores and INR 5 crores- will be required to use 2-digit HSN codes
    • Businesses with turnover equal to INR 5 crores and above - will be required to use 4-digit HSN codes
    • Imports / Exports -8-digit HSN codes
    • Services-5-digit SAC codes
    Points to Note
    • Small dealers under composition scheme will not be required to mention HSN / SAC codes in their invoices.
    • HSN / SAC codes will need to be mentioned in invoice and mentioned in the GST tax returndetails, which will be uploaded on the GSTN portal.
    • At the time of GST registration/ GST migration , the HSN / SAC codes of the supplies a business deals in, will need to be mentioned.
    Verify GSTIN details online
    cta banner image
    Published on November 21, 2019
    Talk to an advisor
    Get the right solution for your business
    Every business runs differently. Tell a TallyPrime advisor how you work, and get a recommendation that fits your size, industry and compliance needs.
    Buy TallyPrime
    Explore all plans | Compare options | Buy and get started
    See pricing
