transparent-sheet-left
transparent-sheet-right
GST State Code Finder
Find the correct GST state code for any Indian state or union territory
GST State code for West Bengal
State/ UT
West Bengal
Code
Get 7-days free trial
TallyPrime makes GST state code management effortless
  1. Auto-fills the correct state code based on party location
  2. Ensures accuracy in GSTINs across transactions
  3. Supports multi-state registrations with ease
  4. Correct state codes reflected in GSTR-1, 3B, and e-way bills
  5. Minimizes errors in e-invoicing and GST returns
File confidently. Invoice accurately. Stay compliant — effortlessly.
Take a free trial arrow-up-right-black
Features of the GST State Code Finder Tool
Our online invoice generator is built to simplify your billing process. Here’s why users love it:
speed-up-collections
Instant Results
Find the correct GST state code within seconds — no waiting or manual lookup needed.
optimize-invetory
Search by State or Code
Type a state name or browse the full list to quickly identify its GST code.
negotiate-suplier
Mobile-Friendly
Access the tool anytime, anywhere — it works smoothly on mobile, tablet, and desktop devices.
manage-expenses
Downloadable List
Export or download the complete GST state code list for quick reference or offline use.
plan-for-growth
Secure & Private
We value your privacy — no personal data is collected, stored, or shared.
plan-for-growth
Updated & Accurate Information
Always get the latest GST state codes as per official government records to avoid errors in billing or filing.
Why Use a GST State Code Finder?
If you deal with multiple states or handle GST registrations, invoices, or returns, knowing the correct state code is crucial. Our tool helps you:
Find GST codes instantly by state name
Avoid invoice or filing errors due to incorrect codes
Save time during GST registration or billing
Who Can Use This Tool?
Our GST State Code Finder is ideal for:
Businesses issuing GST-compliant invoices
Accountants and CA firms handling multiple clients
E-commerce sellers and MSMEs filing GST returns
Anyone verifying GSTIN details or invoices
Explore Our Popular Tools
What are GST state codes?
GST state codes are two-digit numeric codes assigned to every state and union territory in India. These codes are used in GSTINs (GST Identification Numbers), e-invoicing, e-way bills, and return filings.
State Name GST Code
Maharashtra 27
Delhi 07
Karnataka 29
Gujarat 24
Tamil Nadu 33
Example: A GSTIN like 27ABCDE1234F1Z5 shows that the taxpayer is registered in Maharashtra (27).
Why state code matter?
Even a single wrong digit in your state code can lead to:
Rejection of GST returns or e-way bills
2
Mismatched GSTIN entries
3
Delays in order dispatch or ITC claims
Penalties during GST audits
How TallyPrime helps you stay GST compliant?
how-tally-prime-helps-you-stay-gst-compliant
This means fewer mistakes, faster filings, and seamless compliance - even when dealing with multiple states
Pro Tip
If you're operating across multiple states or have branch offices, using the correct GST state code for each registration is non-negotiable. TallyPrime keeps all your state-level GSTINs organised and auto-linked to transactions — so you don’t have to.
pro-tip-img
Let TallyPrime handle State
Codes for you
Import bank statements and create vouchers to complete your accounting process.
state-code-for-you-img
Read Our Insights
Frequently asked questions
A GST state code is a two-digit number assigned to each Indian state or union territory that forms the first part of your GSTIN.
It identifies the state of registration for a business under GST and ensures correct filing of returns, invoices, and compliance reports.
You can use our GST State Code Finder Tool — just select your state and get the correct two-digit code instantly.
Using an incorrect code can lead to invoice mismatches or GST return filing errors, causing delays or compliance issues.
Yes, GST state codes are fixed and standardized by the Government of India. They do not change over time.
The GST code for Delhi is 07.
The GST code for Maharashtra is 27.
Yes! The first two digits of any GSTIN represent the state code. For example, in “27ABCDE1234F1Z5,” 27 = Maharashtra.
Yes, our GST State Code Finder Tool is 100% free to use — no registration required.
Absolutely. It’s fully responsive and works on phones, tablets, and desktops.
